Seawheels
Everything posted by Seawheels
  1. Thank you Jason
  2. Thank you Jason
  3. Thank you Chad and Jason
  4. Thank you Jason!
  5. 1987 Jeep Comanche Pioneer long bed 4x4 metric ton package and roll bar option 119" wheelbase Manufacturing date unknown, sticker faded and not legible 4.0L six cylinder, NP 231 transfer case, original equipment Dana 44 rear and Dana 30 front axles converted to 4.56 gears Leigh Performance Machine (strokedjeep.com) 60mm throttle body, four hole fuel injectors REM monitor (NickInTimeFilms) Front and rear cameras Unknown manufacturer front winch bumper with Super Winch 10K wire rope winch Dirtbound Offroad rock sliders, rear bumper and corner armor. Rigid Industries dually flush mount LED lights mounted in rear bumper. Dirtbound battery mount and Optima yellow top battery. After market receiver hitch BFG KO2 33" tires mounted on steel wheels Bed Rug truck bed liner Custom head liner SWAG Offroad 24 gallon Rubber Maid action packer box mount in truck bed Dash gauge swap by previous owner odometer mileage unknown but near 200K based on CaxFax history J.W.Speaker LED head lights In regular use and located at Santa Fe New Mexico USA
  6. 1987 Jeep Comanche short bed converted to truggy with 1.75" DOM tube back half, 112" wheel base Manufacturing date unknown, sticker painted over and not legible 4.0L six cylinder, Advance Adapters Atlas 2 transfer case with 4.3 gear ratio. Late 1970's Ford 3/4 ton axle set Dana 60 rear and Dana 44 front, 4.88 gears. RCV CV axle shafts in front axle. Rear axle has Eaton Detroit locker front axle has Eaton E-Locker4. ATX slab bead lock wheels with BFG Baja KR3 40" red label tires Power tank bottle mount on rear tool box. Derale transmission cooler on rear toolbox K Suspension triple radiator fan setup with switched third fan Front end doved Warn Zeon 8S winch M.O.R.E. (Mountain offroad) stubby front bumper Napier hood vents Leigh performance machine (strokedjeep.com) 60mm throttle body four hole fuel injectors PSC full hydro steering Reid Racing front knuckles Four link control arms front and rear. Rock Hard 4x4 interior roll cage KC Hilites DOT approved head lights, fender well LED rock lights In use as extreme rock crawler and located at Santa Fe New Mexico USA
  7. 1991 Jeep Comanche Eliminator short bed 4x4 Manufacturing date 3/1991 Engine swapped with LS1 350ci motor and 4L60E automatic transmission from 2002 Chevrolet Corvette NP231C transfer case Rugged Ridge XJ bucket seats, Corbeau seat brackets Custom exterior roll cage by JenCor Farmington NM J.W. Speaker LED head lights 97-01 XJ front clip In progress project build, next step is JKU Rubicon front and rear Dana 44 axle swap using Artec JK to TJ axle truss and mount kit. Building custom dash. GenRight TJ center console. Dual battery and dual air compressor systems mounted in truck bed tool box. Located at Santa Fe New Mexico USA
  8. 1992 Jeep Comanche base model short bed 4x4 4.0L six cylinder, 5 speed AX15 transmission, NP231 transfer case, stock Dana 30 front and Dana 35 rear axles Build date 10/1991 248,000 odometer miles AFE Power cold air intake, 4 hole fuel injectors, Leigh Performance Machine (strokedjeep.com) 63mm throttle body Downey Products bed cover J.W. Speaker LED head lights 31" Goodyear Duratrac tires Located at Santa Fe New Mexico USA
  9. Thank you for the referral to jeepsticker.com exactly what I was looking for and best price too for tailgate and side eliminator decals
  10. https://lascruces.craigslist.org/cto/d/1986-jeep-comanche-4x4/6818866079.html
