jayizle
Everything posted by jayizle
  1. i'm still having problems trying to find out what is the problem
  2. me personally i would just do the d loop. its quick and easy to find. when i bought my mj i have no rear bumper and all i did was take a xj bumper cut it down and welded it. i didn't have mounting brackets for mine. :cheers: but if you put lights for the licence plate then make sure you cut to fit and not cut to big.
  3. as long as you plan on building that iron to the brackets your fine but if you weld that iron on find someone good because i welded my bumper on and it has holes in the sheet metal now :grrrr:
  4. well the add a leafs where like 100 a peice and i don't remember how much the spring was. one of the best things to do is go online and find a off road place and see what there lift kits cost
  5. all i did with mine is was a three inch spring and two add a leafs on both sides. i can get 33's on there
  6. alright i'll do that. hopefully that fixes the problem with no brake lights
  7. is your rear springs under the axle or over the axle?
  8. i'm not sure about that one is your mj sprung under?
  9. i like what you did. very nice but you should have done dual stacks instead of one but other than that it looks awesome :bowdown:
  10. definetly get a lift kit. it will help you out alot. one for the trail and two it will look better
  11. well i checked the fuses today and there are all still good
  12. it is a column shift but its dark here so i can't do that tonight
  13. well i did that cause my father had an xj and had that happen but they and dual filament bulbs
  14. ok so i have turn signals and i have dash lights. i have all my lights but my back up lights and my brakes lights. when i turn the light switch on i have lights in the rear. i haven't check my fuses yet
  15. well i know about the ground i'm going to grind don't the metal a little more sense i just painted it and the plug is fine. i unplugged it and plugged it in fine. i just don't know what the heck is going on
  16. i have a 1988 comanche and have a electrical problem in the rear of the truck. i have no back up lights or brake lights. i replaced the turn signal flasher and all the bulbs
