Jkics
Everything posted by Jkics
Thanks for that but I also show only fits 88-90 and doesn’t fit the 87. Would you know why the difference? Looks like the right thing.
Number one on this image. Factory part number is 53004379 i seen somewhere on this site where Napa 715-1367 with work but they reference to the 88 -90 models. Factory also refers to a different product number for 87 vs 88-90. Anyone have any inside info on why the difference?
I am needing one of these. Who’s got one for Sale thanks
A local guy here in town. Complete redo of seat, visors and dash mat that matches the seat. All for 375
Mine is tan as well, i need cigarette lighter and drivers side arm rest and bracket. Also if you want to sell the outside mirrors I will take them as well if they are the manual ones.
Something I notice yesterday only when my lights are on. The right blinker light stays in. But works correctly when the blinker is actually turned on. Any ideas or thoughts for a fix?
and I would rip up the upper frame bits too. they have proven to be unnecessary and just trap rust inside. I'm sorry, not sure what this is
There is some rust and a couple small holes that will have to be fixed first.
my black vinyl flooring including the insulation under it is all shot beyond repair from the seat forward. What has others done to replace and look nice. Son in law wants to spray line it then come back weathertech type floor mats. Of course he is a body shop guy. Does not sound like a too bad idea though. Any thoughts or theories.??
where do you get this?
It's just strange that it runs great one time and next time not so much.
Didn't really just sit in one spot. Father in law mostly used it as a yard truck moving limbs around. Not much driving on the road as much
87 Comanche 6 cylinder 4 liter 146k on the clock but engine was rebuilt @110k Only about 20k miles in the last 12 years, now that I have it back I want to drive it. Recent mechanic and maintenance things we have done Crank sensor and coil has been replaced and the rear brake line repaired. Drove fine going home and to town the next day. The following day as I was going to town it start missing so I turned around and parked it at home. Replaced the fuel filter and plugs. Run great, even better than the previous day. Drove to store to fill up with gas and added a bottle of sea foam. Got on the interstate, did great at high speed (70 ish). Drove to town the next day and did a lot of starting and stopped with errands to do. Even took to the shop and greased the front end and found where the ac line was stopped up and leaking inside but they unplugged that. On the way home got into the heavy rain storm then about 3 miles from the house, it was like running on half power all the way home. Only could do really slow. Idles good but only cuts out when I give the gas. Since then I replaced the distributor cap and rotor drove done the road, seemed to do fine. Started it again later that day now its cuts out again. Replaced the plug wires next and still cuts out. Need advise on where to go next.
Having issues finding these, does anyone I have at least one?
Good info. Thanks
Ok thanks. I will do that, but my floorboard was wet.
In looking over my new project, I tested the washers. Nothing came out on the windshield but did come out on the inside. Is there a way to get to the line without pulling the dashboard? There are no leaks on engine side.
