First post so hey, nice to be here, but I've recently acquired a '89 MJ that has been giving me a bit of trouble. The turn signals began flashing slowly under normal operation, then when the brake is applied they go solid. All four lights are working, tested with the hazards (which the button for is not present so that was 'fun') and they worked. The left seems to be functioning semi-normally, but the right is giving real issues. If the truck is off, with the key out, pressing the brake turns the brake lights on as normal. If I swing the blinker lever to the right, and THEN depress the brake, the blinker dash light comes on solid, and so does the radio and other electronics. I've replaced both the flasher unit (bottom one on the fuse panel, was that right?) and the right rear brake bulb, and the symptoms continued but the flashers worked at the normal rate under all conditions thanks to the new electronic flasher. The truck is actually sitting at work waiting for one of the techs to do the differential rebuild so I don't have it with me, but I'm gonna try replacing the left bulb too since I have it anyway, and double check the sockets of both when I get back to it tomorrow. Grounds have not been refreshed yet.
It did spew coolant from the bottle before this happened so I dunno if that screwed with anything.
