DC Dave
Everything posted by DC Dave
  1. I battled water leaks for most of 2020. I had no idea it leaked so much until after I installed new floorpans and drove around with no interior for awhile. These are the leaks I found: Antenna grommet (sealed with seam sealer) Blower motor (new weatherstripping) Firewall grommet on hood release cable (replaced cable) Fuse block (new weatherstripping) Random plastic trim fastener below the fuse block (seam sealer) Rear window (removed and reinstalled glass) The vertical body seam below the rear glass in the corners on both sides. (seam sealer) Door weatherstripping (replaced) My XJ also leaked at the roof/body seam under the rain gutters and through the rear door due to a missing vapor barrier behind the trim panel.
