CMRCTRY
    Gig Harbor
  • Interests
    Search & Rescue 4x4 Unit
312 profile views
CMRCTRY's Achievements
  1. Eagle or others that have knowledge. Is the below a viable configuration for adapting to a Ford 8.8 with disk and duel diaphragm upgrade? "The simple way to eliminate the rear height sensing valve is to disconnect the rear axle flex hose from it, run a new hard line from the "nose" of the front distribution block directly to the rear flex hose, and to plug the forward/lower output on the distribution block. That's it -- done." Or WJ valve with the intent of upgrading to full WJ front brakes in the future? Thanks,
