speedracerjer
Everything posted by speedracerjer
  1. Thank You for the info, I do not believe this truck has the emission timer. I did find a printed circuit board card with 5 diodes on it plugged into a black box, when I remove the card, no check engine light. So I am getting somewhere. Just need to figure out where or what is sending the 6 volts to make the light stay on. Any help is great.
  2. 86 MJ, 2.8L dog engine, getting code 12 which from what I read in the Chilton manual is just a self diagnostic code while the engine is off, key on. Start the engine, no codes but the light will not go off. Disconnectred the battery for a few minutes, still on. Pulled the ECU and reinstalled, still on. Any thoughts?
  3. Image Not Found Image Not Found Image Not Found Image Not Found Image Not Found
  4. Well here are the pics I promised of the floors. Pleasantly suprised at the results. Made a light repair with a wire wheel, rustoleum primer, and a little red paint I had in the garage. Image Not Found Image Not Found Image Not Found Image Not Found Image Not Found And here is the nicest AM/FM cassette I have seen in a while. It works too!!!! :clapping: Image Not Found
  5. I haven't pulled the nice, blue, house carpet up yet!! I'll be doing that later this evening or tomorrow. I'll post pics along with the results.
  6. Well, I just finished installing the rebuilt tranny, new fluids, changed the oil and took it out for a maiden voyage of about 1 mile round trip. WHAT A DOG!!! This 2.8 really lacks in the HP dept. Overall, it drove pretty well. Still need to bleed the clutch master cylinder a little. Still wanting to shift hard and grind a little. Its late, I have to work tomorrow, so maybe by tomorrow night I can get that clutch adjusted in a little better.
  7. I'm going to have to say I have the part time since there is a vacuum system that pulls the front axle into 4WD. Not to familiar with this kind of system. Any good threads here about the vacuum system? All I have done for a week is read posts in the project section about everyone elses builds. Lots of cool and unique ideas.
  8. I thought it was a good deal for $400, even with the tranny issues. Still has tags til 10/09. Once I'm sure it is road worthy, the customization will begin!!
  9. It is actually a 2.8 V6. I'll keep it and see how she performs. Has to pass smog here in CA.
  10. Great forum! Here are a few pics of my recently acquired 1986 MJ XLS. Soon as I got it home, the worn out AX-5 had to be removed and sent out for repair. I was getting reverse and 5th at the same time!!! ENJOY!!!
