The engine would start as usual, but run for only 20-30 seconds then die.
It seemed like a fuel supply problem and and the Troubleshooting section in the Haynes manual indicated this problem would be covered in the fuel supply section. It wasn't, specifically as far a I could tell, but I went through the test procedure, connecting a fuel gauge to a fitting on front end of the fuel return manifold and starting.
The meter didn't deflect from the peg, either initially or when I removed the vacuum hose or when I pinched the return hose as instructed in the manual.
I didn't feel confident enough in the gauge reading at that point to start disassembling the fuel supply lines.
A search directed me to a discussion in this forum about a similar problem, where several possible electrical issues were discussed, including a defective "ballast" resistor.
I found a resistor mounted on the driver's side front fender.
When I pulled back one of the wires to bypass the resistor a (broken) connector lug pulled away from the resistor.
I connected the leads together, started the engine and ran it for over a minute before I shut it off.
At this point, my concern is the incorrect gauge reading.
I'm not an expert and just learning the engine systems as I'm studying this problem. The pressure test equipment is a new-looking unit borrowed from an auto parts store. I doubt the engine would start at all if the 0 psi. reading were correct.
So I'm wondering if there might be an error in the way I connected the gauge.
I used the GM coupling that came with the kit.
I didn't remove the check valve from the fitting on the truck, but I believe I was not instructed to.
I have run the engine with the test assembly connected and there is no fuel leaking in the vicinity.
Thanks,
Dale
