guadinomj
    long island
guadinomj's Achievements
  1. I did 1-6 and 8. still nothing but I'm happy i did them! any really important spots i should look in the harness when i open it to look for lose terminals and bad wires.
  2. 1987 jeep comanche 4.o remix, i do not have spark motor spins when you turn the key. no voltage to the male end of the ignition male end! i have power to the ignition module! i put in a new cps, ignition coil and ignition module. i purchased the car not running so i don't know the history of it except that it was running in 2009. i have swapped computers and found out that my ecm is working properly. I need help with what wire tells the ignition module to create spark any ideas with help!
  3. i figured it out! thanks though i was just over thinking it!
  4. i can't find out how the bracket for the alternator gets mounted to the motor. everyday i try doesn't work I'm sure its simple but it's not working. pictures will help!
  5. i wanna swap my 87 column shifter to an xj shifter so i can have cup holders! but i was worried that the shifter cable on an 97+ xj shifter cable wouldn't hook up to my tranny. any ideas or pictures that show it works would help. thanks
  6. i don't have a paypal but i was wondering if i could send some money in to get a wind shield sticker and a cozy. if you can pm an address i can send cash to that would be great. thanks
  7. i have been gathering mew stuff my 1987 mj. i purchased a junk yard 4.o remix with an estimated 100,000 for 275 i bought a new radiator all new hose battery cables starter belt vacuum hoses sprk plugs and wires water pump and a bouncy of random little stuff right now the headers and manifold are on the motor and also the water pump. should i put anything else on the motor before it goes in?
  8. alright thanks sounds like I'm gonna be stuck with a full window for a while
  9. looking to find out a website or anything for a rear sliding window in my mj. i have a one piece window in it now and i hate it.
