beeseliminator
beeseliminator's Achievements
  1. if you are savvy with a welder, i used 2x5" steel tube. cut it to length and angled the ends to match the body. took the original mounts and shortened them. welded it up. its simple an looks good. if you wanted a receiver it would be nothing to cut a hole in the center and weld it in.
  2. there is also a ac delete pulley you can purchase or find in a junk yard, my eliminator never had ac. Came from the factory with it. This way you can just use the normal size belt.
  3. The CPS (crank positioning sensor) is almost always the number one culprit for not starting or the vehicle just shutting off.
