willbur16g
Everything posted by willbur16g
  1. What kind of welder/settings did you use to weld the bed back together?
  2. i agree with the bob. what i plan to do with my future mj :thumbsup:
  3. oh ok thanks. Are crossmembers the same?
  4. I'm live in california in the yosemite area. thank you both for the answers. the speed sensor on tc has the same connector right?
  5. ok. id like to avoid it if possible but i was just saying lol. if no codes are thrown and it works perfect thats great. also i read on a different thread that both shifters can be used with the aw4 transmission, id like to leave column shift. could you check the part number for the tcu? thanks
  6. i want a semi seem-less swap. completely comfortable with harness work. details are very appreciated.
  7. so what would need to be changed from the cherokee harness to work in the comanche?
  8. are there any year cherokees that would not work? would the column shift still be functioning or converted to floor shift? did you say that the front drive shaft is the same?
  9. does a 1992 4.0 2wd comanche come with the two wheel drive aw4? if so are the transmission harnesses the same between that and a four wheel drive aw4? looking to buy a 2wd comanche and swap it to 4x4, i understand almost everything i need but I'm not sure about the transmission. New to the topic so please understand i am a newbie.
