Jeep_PDX
Jeep_PDX's Achievements
  1. Awesome, thanks!... got everything except the Pin Puller... the one from Summit will ship next month. Gotta figure out a way to get one by Saturday.
  2. The special tools is what I am going to try and buy before the job... question is, will anyone at Autozone or Napa know what to get if I say "lockplate tool" or "Pin Puller"? Does not seem like these are vehicle specific, but I hope that I can provide info to get what I need.
  3. and just to get an idea of how labor intensive this fix is... Is a day enough to get this done? I'm mechanically inclined but by no means an expert here...
  4. Thanks! Looks like the ticket. Much appreciated, Alex
  5. Hello... new to the club :) I have an 86 with the 2.5 FI. A couple of months ago the steering wheel and column started loosening up around its center... it got worse with time. Basically the wheel can be moved laterally and vertically in a "cone" type pattern. What works: -tilt mechanism -turn signals / wipers -steering function (no rotational slop) What's bad: -high beam function only works by slightly tilting the wheel upwards -ignition block feels sloppy and sometimes jams (still I can get the truck started every time) -laterally pushing the wheel (due to its slop) to the left will cause a break in electrical contact to the ignition (probably the worst aspect of this problem) Need to understand exactly what component needs replacing (column?) or if this one can be repaired. I have access to a shop and can tinker... but not sure what to start taking apart here. Thanks! Alex
