Dennis
Everything posted by Dennis
  1. Thanks for the Pics I took the water pump off it had a little wear on the blades I don't know if this is my problem but I ordered a new one anywayhttp://s71.photobucket.com/albums/i145/DCB4GOD/?action=view&current=Fanpump.jpg
  2. Hay I found one at a junk yard but a pic still would be nice I still have an over heating problem I have changed the thermostat the radiator cap & put on the junkyard shroud it still gets hot also flushed it out :?: :(
  3. Make it work Please :cry:
  4. I need to see a pic of a fan shroud on a 2.5 MJ I found mine didnt have one and I can't find one in theis town so I'm gonna make one .weather warming up and its running hot
  5. O'Rielys has gotten everything Ive needed so far for my 86 some of the parts were exclusive to 87 my truck was made in the latter part of 86 :-D
  6. the rub is on the fender thanks for the info
  7. I put 31s On mine also noticed a little rub when i made a sharp turn What is the cheapest and esyest way to get a 1 1/2" LIFT ON MY truck
  8. Ok thanks . Will the Transfer case fit mine?
  9. A buddy of mine Is giving me parts off his 89 Cherokee it has a V6 4wd Mine is a 2.5 1986 Comanche 4wd I'm getting the seats and the dash but what in the engine compartment will fit ?Starter any of that stuff? Dennis
  10. thanks Ill look into it
  11. :?: I have a 86 long bed I salvaged needed a little work I have done a lot to the front end replaced both hub assemblies its driving good but both tires lean in at the top slightly I have not found an adjustment and there is no slack in the works also do they make a valve cover for the 2.5 that isnt plastic? l'll have a lot more ? as the work progreses this is just ths begining :-D
