To get started I have an 87 Jeep Comanche Laredo with the 4.0L engine and 4x4. The transmission is the 3 speed auto.
This morning the Comanche started up fine but about 2 minutes into the drive she just stalled out. This has happened before and I just put it in park and she fired right up. About 6 hours later I was going to lunch and she would not start. The engine was cranking and she would sputter a bit as if she wanted to start but she wouldn't. After about 10 min I sprayed some starter fluid into the intake, she didn't start the first time but after several tries and putting starter fluid in the intake she fired up and I got her home. This is the second time she has done this and now I fear it's permanent, a few hours after getting home I tried again and she still failed.
Work to date:
I replaced the fuel injectors and the air throttle valve about 1.5 years ago.
I do not remember the last time I did plugs and wires and distro cap.
Replaced all of the engine bay vacuum lines.
The battery is less than 2 weeks old.
Fuel filter was replaced 3 yrs ago.
Odd symptoms:
I hear a strange buzzing/hissing coming from the vicinity of the fuel pump(assuming its the circular thing on the fuel tank). I put my hands on the vacuum lines in the area and could not detect a leak. I had the car in a garage this winter and prior to taking it out I have never heard that sound from the fuel tank.
Spraying carb cleaner will eventually get her started but takes multiple attempts.
If the engine is warm she will start.
I plan on checking the fuel pressure at the rail this afternoon...
Any other tests i should do to narrow down the problem?
Also, if it is a fuel pump issue how do i tell the size of my fuel tank? All of the pumps are for either 16 or 20 gallon tanks... i want to make sure i order the right part.
