lanciat
lanciat's Achievements
  1. One other thing to check for when experiencing turn signal problems -- the metal spring holder for the fuse within the fuse block itself. I experienced turn signal problems in my '89 Pioneer for the better part of three years, and threw parts at the problem (new flasher, new turn signal switch, complete set of new fuses), only to see the problem reoccur periodically. Turns out that, upon close examination of the fuse block, the metal spring holder in the block for the turn signal fuse had broken (only half of it remained in the block). My electrician solved the problem by routing that electrical line to a new auxilary fuse holder. Don't know whether the spring breaking was due to clutch fluid leaking into the fuse block from a failing clutch master cylinder, or whether the fuse holders simply become brittle over time. But, for those of you with wonky turn signals, it's worth a look.
  2. Thanks very much. :bowdown: Looks like it's shaping up to be a complete disassembly of the door. I'd better make sure that the regulators I pull from the bone yard are good . . . . Once I remove the vent window and rubber wipes for the main window, I suppose it's simple just to pull the main window glass out of the door? I ask because it looks near impossible to remove the bolt assembly from the bottom of the main window glass after loosening the nut that holds the glass to the regulator -- the plastic and metal discs on either side of the glass appear to be glued on. Do those discs interfere with removal of the main window glass from the door?
  3. :dunno: Anyone? How about this: the vertical cross brace in the lower door opening that I'm referring to appears to be the regulator guide bar (don't know if that's applicable to manual window regulators like mine, but it appears to be the case for power windows). If I'm right, it has to be un-riveted and removed in order to get the old regulator out of the door. Can anyone confirm?
  4. I'm getting ready to replace the passenger side window regulator in my '89 MJ, and have found lots of helpful information using the search feature. But there's one aspect of the project on which I haven't found much information: namely, tricks on removing the existing regulator from the door. Is it necessary to remove the vertical cross brace from the large opening in the bottom of the door (the brace is riveted in place in my MJ) in order to remove a regulator that has otherwise been unbolted/unriveted from the door and window glass? :help: Thanks in advance for any and all help!
