NH_JeepBuilder
Everything posted by NH_JeepBuilder
  1. Sorry to bring back and old thread... I have been looking at and hopefully going to be buying there long arm upgrade for my 86 comanche. As for notching the cab support, how much did you cut out of it? Any pictures? I've heard a mix of both good and bad about the kit. I have had only but good things to say about RC, I have had three jeeps and each one I have used RC for the lift kits.
  2. Hey everyone, new to this site. I just picked up a 86 Comanche, it has a motor, drive train and axles from a 91 Cherokee(4.0 automatic). Not sure of the gear ratio in those axles... It also has a "5" inch lift already installed (5" coils upfront and spring over in the rear). The interior has been taken apart but all the electrical has been neatened up and all ready to be put back together. I know that it needs a new fuel pump, sending unit, radiator, serpentine belt, AC delete pulley, front and rear brake lines. I have ordered everything I need to get it running, I now just need the time to put it all in. My plans for this rig are to swap the front coils out for some 7-8 inch lift coils, RC long arm kit, rear 2" shackle and maybe and AAL to match up with the front. SS extended brake lines front and rear. I have a set of Cherokee axles(HP30 and chrysler 8.25) with 4.56 gears that I would like to swap into it. 35" pro comp M/T's on some black steelies I have kicking around. Home made bumpers front and rear, front will have a RC 9500 lb winch that I was going to use on my YJ buggy I was building. Cut out the rockers and weld in some 2x6 tube for rocker rocker protection. and maybe build a rack for behind the rear window. Will post up pictures as soon as I can.
