stevep6
    Nashville, TN
stevep6's Achievements
  1. Will this hardware set not work? http://www.4wd.com/productdetails.aspx? ... artID=8581 I know it's for a Cherokee, but I thought the mounting hardware would be the same? I have pulled one of my flares off and broke a stud; the slower you work (and the more rust penetrant / lube you use) the better your chances are :)
  2. Hi All - new member here with the first (of many) questions :) 88 MJ with manual window lifts, I would really like to replace both flex cables while I have the truck apart. But I don't want to pay $150 each for new assemblies. The power versions seem to be more common on eBay and I am wondering if anyone has ever taken the flex cable from a power unit and put it into a manual one? In reading the boards I also wonder if we know: a) are the fronts from both the 2 & 4 door cherokees interchangeable with an MJ (I think yes?) B) cherokee rears: the mechanism is slightly different but how about those cables (same length as fronts?) Thanks! BTW - While I have this apart if anyone wants door/window pics just let me know. I was actually pretty surprised how quickly drilling the rivets & removing everything went! Below: Manual regulator - the cable is 41.5 inches long Below: Power Regulator
