parker454
Everything posted by parker454
  1. all the things done so far on my xj and my comanche coud not have happend without the help of a freind who knows more than me about jeeps so i have to say thanks to scott for his help.
  2. i thought i seen where you said it has two inch blocks ? take them out that will lower your front :chillin:
  3. hey thanks for all the input ,it helps me alot :chillin:
  4. i like a manual too,will everything work with 410 gears 35 inch tires.and a ax 15? and thanks for your help. :chillin:
  5. Brent thanks for your input it helps alot.Yes i have the complet harness.the mj is already set up for a standard,has all the petels, master.for clutch .had a four speed in it with the 2.5. john :chillin:
  6. thanks brent ,i stripped a 91 xj for all the parts ,took all the harnesses out ,fuse block ,the whole work,s ,to put in mj ,will that work?and if you don't mind me asking,are you the brent that put leafs in the front of his mj?thats what i am gonna try to do,any suggestion?and thanks for your help ,need all the help i can get. :bowdown:
  7. hi my name is john ,just bought my first mj ,i want to thank corry for directing me here for help on my project,and i want to thank anyone for advice,its a 86 mj just put a ford nine inch in the rear,working on floor pans,changing motors took out 2.5 putting in 4.0 .gonna do leafs in the front .has a automatic on 4.0,need advice on do i keep it automatic ,or do i go standard ,and what would be best standard?HELP PLEASE :bowdown:
