Jindo's Truck
Everything posted by Jindo's Truck
  1. Check the link in my first post ;) .Blhtaz: Can you look up part numbers for the injector O rings, Chilton has a part number that includes O rings for all the injectors and the the fuel pressure regulator(6brown&7black seals)don't know how accurate that is?Can you just buy the O rings for the injectors? I work at a Jeep dealership in the parts dept. New injectors sell for $69 - $99 EACH :nuts: . That is not calibrated though. If you start with 6 injectors that are not "flow matched", you are still going to have 6 injectors that are not "flow matched" after they are all cleaned up ;) ...therefore, not calibrated.
  2. Thanks for the replies, I suppose if i change one the others should be changed? Anyone know the dealer prices?
  3. Are they hard to change, screw out, any special tools required? Should I look for a Mopar one?
  4. Mine only has the one screw holding it in place,under the transfer case plate.Maybe it was designed to float!
