jahiatt
Everything posted by jahiatt
  1. My radio turns on and I can hear the humming in the speakers, but no stations will pick up . Don't know much about vehicle radios. It worked last week and sounded great. Antenna? Any help??
  2. Thanks, it was the white 3 prong under the dash next to brake cable. It wasn't bad so I removed the horn and used sandpaper for a better ground. Horn works now.
  3. My horn doesn't blow. Jump wire it and both will sound off. All the fuses are new in the fuse block. Ive cleaned the metal disc in the wheel. ' When I press the hown disc, I can hear a slight clicking. SOMEONE PLEASE TELL ME WHERE THE HORN RELAY IS LOCATED. EVERY MANUAL I HAVE SAYS NOTHING ON RELAYS OR THE HORN. MAY BE THE RELAY, MAY NOT, I JUSTT WANNA KNOW WHERE ITS LOCATED. 1986 COMANCHE X 2.8 5 SPEED
  4. Going to POR after I finish replacing the floor pan. Almost there.
  5. I rotated the pic and circles the bolt or plastic plug. It have a rubber gasket gasket and it leaks a drop or two. Another just like it under the dash and blower , It leaks a little also. Someone know where they can be seen on the firewall side? Down in the cowl?
  6. I looked at the xj price and I may get it. Thanks for offering. Somebody who owned the truck earlier chaulked around the chrome trim and it may get damaged when removed if I decide to get a new windshield. (leaks)
  7. Anywhere to get new windshield trim or just the JY?
  8. fuse block.........the pic needs rotating clockwise :doh:
  9. Leaks at the bolt head beneath the fuse box. Identical bolt on passengers side. can't see them on firewall side. Help me out!!
  10. Can anyone help me out on taking apart the fuse block on a 86 so I can try to seal and fix a water leak? I hate fooling with wires, is it just plug and play? Thanks
  11. where can I get the "best fitting floor pan"? for my 86 front driver side? classic2current at RockAuto for 41.99. Anyone used this one? LH is drivers side, correct? I have the ability to make a descent one, but would like more professioal look. Thanks
  12. The inside are the same. Its the outside thats different, and the outside are dry rotted on the donor cherokee.
  13. I must be totally dumb then. The inside wipes fits over a seam, the outer wipes use the metal clips and sllides dow. I've taken the inside ones off a 1988 cherokee 4 door and wanting to put them on the outside of a 1986 comanche They are not the same. Whats going on. Everyone says they will work, whats my problem?
  14. I took the inside wipes off my 1988 cherokee and they will not work on the onside of the comanche doors. Too fat and shaped totally different. They fit over the metal seam instead of clips which the outside wipes use.
  15. Any info on how to remove and replace the window wipes and where I can buy them would be helpful. Water pouring in , cut out the drivers front floor panel today. Only found one supplier and they are quite expensive. Also, I was running my heater today drying the floor and I was looking under the dash at everything and noticed smoke at the fuse block. The 25a fuse for the heater was getting hot. Any ideas? Also, anyone have a pic of the spare tire hanger. Its missing and the spare is in the bed. Also, no lights in dash for turn signals and emergency blinkers. They work fine outside, and you can hear the blinking in the dash, just can't see the arrows. Love to find the plastic insert for the console. Mine is cracked. I'll post some more in a few days. one more thing, 2.8 is weak as grandma, but I knew that
