jdemonto
Everything posted by jdemonto
  1. Bought it July 2012 got lucky I guess! Jason
  2. Its not finished but are Jeeps ever? Its not my Jeep so who knows maybe it will never get done? Thanks guys for the kind words, maybe we can get some trail pics after the 4wd gets finished up. Jason
  3. **Update Added C-ROK Steering box plate and a new steering box Cut and moved the front fenders up nearly 2" trimmed back about 4"
  4. A little paintshop work what do you think? I moved the fenders up and widened them.
  5. Cut the inside edge about 3" from the pinch weld and weld or bolt in tabs to keep them pushed out. I had a 1988 Ford Ranger Pre-runner years ago very common with those. Here's a good site for the how too Jason
  6. After rear Day Star Add A Leafs Pulled rear bed sides with 35" tires no cutting Pulled bed sides with 31" tires
  7. Synergy 4.5" Front Coils and painted the grill black Synergy Suspension lower control arms. We like the oem bushing and the Johnny joint on the opposing side completely rebuildable. Scored a set of low mileage 35" BFG's on craiglist! Probably need to lift the rear more! Drove it to work today lots of little things to work on. We will be installing the Day Star Add a leaf to the rear in the next week should give us a 2" lift. Wolo Air Horns
  8. Removed the old transmission Sunday that was fun at 102* Finally getting some parts Centerforce II clutch and everything we need to get this installed this weekend. Finally making progress! Repainting front grill etc Installed new Orfab front bumper,trimmed front fenders and est where it will sit with lift. Installing Synergy 4.5" Progressive front coils, On order tracbar and lower control arms
  9. Here's the T-case and Transmission we picked up Ax-15 and NP231 $300
  10. Just picked this up from Vegas last week. My daughters new Comanche project 2wd converting to 4wd and swapping out the trans for a AX-15 for reliability. The rear is a D35 so that's going to be replaced by a 8.25" and a D30 for the front. Our goal is 90% used parts and to keep the total cost under $5K. Build 4wd 8.25 rear axle D30 Front 35's 4.5"" lift Fiberglass Front Fenders Pulled Rear Fenders In Cab cage Synergy Suspension LA Front king 12" Reservoir Shocks Deaver Long Travel Rear Spings Bed Cage Bumpers LED Lights Goal Under $5k Current Cost Truck:$600 Transport:$350 Radiator Fan shroud:$35 Shifter knob:$25 Shifter Boot:$25 Door Handle:$25 Ax-15 Trans W/Tcase $300 Front Bumper:$640 Centerforce II Clutch $385 Misc Trans parts:$100 Drive shaft Yoke $30 U joints $35 Chop and Bal rear shaft $75 External Slave Cylinder $180 Synergy front 4.5 Springs $185 Synergy Trac Bar $225 Synergy Short Lower CA $275 Air Horn $40 35" BFG Tires CL:$600 15" Method race Wheels:$480 Day Star Products Add a leafs:$75 Pulled Bed Sides:$10 C-Rok $68 Shipped Spedo Cable $27 Steering Box $168 --------------------------- Total Cost:$3693.00 Sold Transmission -$100 Total Cost $3593
