I have never done a 4X4 converison before so I need help. :oops:
From what I have read on the forum it sounds almost like a bolt in project.
The project vehicle is a 89 Eliminator, 120,000, 4.0, Auto, PS, AC, 2wd. As it is a AZ vehicle no rust :D only damage is the rear quarter panel by the tailight and the rear bumper.
I have search the forum and I still have a few questions:
When replacing the rear axle with the axle from an XJ can I use the existing XJ spring perches?
I will be using a TC including the driveshafts. from another XJ Auto 4.0
Do I use the XJ rear driveshaft or shorten the MJ rear driveshaft?
I know I need to use the Comanche rear springs.
The complete XJ front drive train will be used, A 3 inch lift kit will be install during repalcement.
Any other tidbits would be appericated.
I just read that you cannot use a 2wd tranny and attached the T case to it.
The local used parts yard has told me in the past that I can make the connection between the 2WD Tranny and the T Case.???????
