Geonovast Posted June 7, 2008 Share Posted June 7, 2008 I had no problems when I put the full cluster in my 2.5, threw on the oil sender and temp sender from an 88 4.0 XJ, cluster from a 92 XJ. I just got a cluster for the 4.0 from Boilermaker, and I pulled the senders from a 92 4.0 in the shed. No problem with the oil sender, but the temp sender plugs were different. Truck has the regular single wire round plug, but the sender had a rectangle plug with one wire. Were there wiring differences from 91 to 92, or is this the result of a hackjob? Link to comment Share on other sites More sharing options...
Guest vzehler Posted June 7, 2008 Share Posted June 7, 2008 its my understanding that 91-92 should be the same. I'm sure someone else will chime in. Link to comment Share on other sites More sharing options...
