onebigmj Posted May 5, 2008 Share Posted May 5, 2008 My 97 xj 4.0 cuts out once in a while. It acts like its running out of gas but when I push in the clutch it revs up like normal. It got progressively worse and I was told it might be a cps so I replaced it. It seemed to get better but not go away. It also started reving high but it only does it while moving down the road. If I come to a stop it idles back down. It throws the codes 12 42 and 21. I know 12 and 21. 21 is because my cat is empty and the down stream O2sensor is bad but I was told it doesn't have any effect on the way the vehicle runs. Sorry for writing so much Thanks in advance for any help Link to comment Share on other sites More sharing options...
