clutch questions
I am converting my 90 mj to 4wd and I got a 1994 cherokee as a donor. My question is-- I had the internal slave cylinder on the original ax15 trans and now the new trans has the external slave. Will the clutch from the original internal slave trans work with the new external slave setup?
Just to be sure I would swap the clutch disc and PP from the donor if they're in decent condition. I'm sure the clutch itself is the same, but the PP may be different. You could call up your local dealership to compare part numbers.
I have the slave and master cylinder and all that, but my donor came less the engine which was less the flywheel, which you guessed it was less the clutch. So I am really wanting to know, if I bolt this thing together is the clutch that I have going to work or am I going to be pulling the trans again?
