Brake Question
I have just purchased a 89 MJ and the rear brakes are currently disconnected. It has the load bearing valve assembly in the back, the question I have is do I really need the valve in the back or can I just replace the proportioning valve in the front. I have a front valve off of our old 94 XJ so I should be able to use that. I just would like to know if I can just remove it.
http://comancheclub.com/forums/viewtopi ... lve+brakes
