dotnetrob Posted 9 hours ago Posted 9 hours ago 1989 Jeep Comanche pioneer 4x4 with 4.0 Automatic Located in Kansas City, MO 64133 190,306 miles Asking $4000 - Stock D44 Rear - D30 Front Unfortunately need to sale my project Comanche. Have had it for about 18 months, drove it weekly for the first year. Haven't even put 5,000 miles on it myself. No longer have the time to put into it due to wife's health issues. Trying to find it a good home and save another Comanche. Pictures - can provide more upon request https://www.dropbox.com/scl/fo/r3j1xij5g5dkqyeczcbld/AGYz0b4g8F4ceUWuEae1jdU?rlkey=qvdt7m2p1qtpr2jf9jgt2psst&st=cb628kx8&e=3&dl=0 Comes with rear camper, was taken off after I purchased the jeep. have a Renix Engine Monitor II from NickInTimeDesign that will go with the jeep repairs done new value gasket installed - fixed majority of oil leak installed new adjustable proportioning valve by brake booster to adjust rear. Old stock proportioning valve was rusted and non functional. installed new from driver axle shaft - old one was rusted to wheel hub replaced all front brakes - rotors, calipers, pads, and dust covers replaced rear pads and springs replaced rear brake lines replaced cps and ignition coil - was trying to diagnose start issue - was fuel hose on fuel pump in the tank that had a broken clamp that was installed by previous owner. new muffler upgrades done led side markers oracle rear led tail lights - have stock ones too. single din touchscreen radio with rear view camera kicker 4x6 speakers kicker 5.25 speakers Behind the seat 8 inch speaker/amp Installed Big 7 Battery Cable Kit from jeepcables.com k&n air filter led headlights new OPTIMA battery parts for additional repairs included replacement floor, bed, rocker panels and inner fender from c2c fab that come with the jeep spare new passenger side axle shaft - new from - Ten Factory Dana 30 '27' Spline Chromoly Axles w/ Disconnect Eliminator , driver side already installed issues body rust - have all the floor, bed, rocker panels and inner fender from c2c fab that come with the jeep frame rust - its a midwest truck so it has rust, see pictures, can provide more pictures if desired. No space wheel/tire. 1 wheel/tire has a bad leak around the bead, rims are very beat up, and tires are old. still has a small oil leak not sure where front since valve gasket was the replace it a small leak A/C is not working, was when purchased, believe has a small leak in one of the hoses, heater works fine. have 31x10.50F15LT installed, speedometer is off a bit and tires rub on sharp turns.
