moparbrown Posted August 20, 2024 Share Posted August 20, 2024 1991 Jeep Comanche 4.0 high output engine Shortbed 5-speed Manual transmission 2-wheel drive 244k miles Vin: 1J7FT26S0ML546868 Build Date: 10/30/90 - Military ordered Purchased in 2017 from used car dealership. They fit in bucket seats and patched the floors. Fixes/updates since purchase in 2017: Degreased and painted valve cover with new gasket Reupholstered headliner Low-profile antenna All new brakes Falken Wildpeak A/T tires in Oct 2017 14k mi New clutch master cylinder New radiator New blower motor & resistor New fuel pump New water pump New thermostat New serpentine belt New power steering pump pulley New rear bumper New headlight switch 2019 April 2019: New LUK clutch master cylinder Heater core flush and new heater valve New grill December 2020: New front bumper KC 6" Apollo Pro off-road lights w/wire kit 6.9 Inch Carplay Single Din Touch Screen Bluetooth Car Radio with backup camera. Will also come with: Comanche badges Haynes repair manual book (Cherokee) Bench seat Misc parts The good: Was my daily driver from 2017 to 2020 (covid) so issues were fixed as they happened. Garage kept. Never offroaded under my ownership. Lots of new parts and repairs. No major rust that I know of- always grinded any out and painted rust preventer. The bad: Has dents and scratches. Driver fender is pretty bad. Thermostat doesn’t always read. Spare tire is old. Original paint is very sunfaded- has been sprayed with rustoleum enamel. Parking brake light is stuck on- likely a switch or it is grounded. Wipers are slow. What it needs: Roll bar needs installed - no brackets included. Roll bar lights need wired (they work). 2 of 4 are KC. Driver front fender needs replaced. Probably a new battery. Speakers are takeoffs from newer wrangler, but are not mounted. Link to comment Share on other sites More sharing options...
moparbrown Posted August 22, 2024 Author Share Posted August 22, 2024 Link to comment Share on other sites More sharing options...
Archived
