need expert help
My producer want to convert the MJ to auto after I went out and got an NV3550 for it. Lazy bum.....
Well the donor is an 96 XJ not sure which tranny it is, either the aw4 or the rh32( by the way which one is better)
I know I need the tranny, radiator, custom line for tranny fluid, radiator and wiring harness, oh and the shifter.
1. is there anything else that I am missing
2. How feasable to you think it will be to wire this thing up.
and any other info that would make my producer happy.
Again Thanks in advance for all your help and info.
Mike Gonzalez
It would be an AW4 from that donor. The 32RH was not used in those that I know of.
The AW4 is definitely a better tranny, just more difficult to install, but as long as you have the complete donor vehicle you should have all that you need in terms of wiring harness, computer etc, etc...
OH...and if it's 4WD, you will need the t-case to go along with the AW4 as well.
