RiversideMJ Posted May 28, 2024 Share Posted May 28, 2024 Hey guys, I just changed my fuel injectors and injector connectors. Of course I had to disconnect the fuel rail, and when i went to connect again I thought it all clipped in good. I decided to prime the fuel pump to make sure no gas leaked before turning on the engine, but there was a leak from the hose that takes the gas into the fuel rail. Not sure if the plastic fuel connector is damaged or if it is the hose. Any tips/hints on what could be wrong. Here is a videoIMG_3561.HEICIMG_3562.HEICIMG_3562.HEICIMG_3561.HEIC 629656655_FuelLineLeak.mov Link to comment Share on other sites More sharing options...
RiversideMJ Posted May 28, 2024 Author Share Posted May 28, 2024 Fuel Line Leak.movFetching info... Fuel Line Leak.movFetching info... Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted May 28, 2024 Share Posted May 28, 2024 You might find this thread helpful: I used the standard motor products HK7 fitting. It worked great. Link to comment Share on other sites More sharing options...
RiversideMJ Posted May 28, 2024 Author Share Posted May 28, 2024 Okay sweet! So you used the HK7/NAPA fitting on the rear and it fit fine? Link to comment Share on other sites More sharing options...
RiversideMJ Posted May 28, 2024 Author Share Posted May 28, 2024 Just took a look at pics I posted, looks like I am missing the o-rings so thats probably why I am leaking. Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted May 29, 2024 Share Posted May 29, 2024 On 5/28/2024 at 3:37 AM, RiversideMJ said: Just took a look at pics I posted, looks like I am missing the o-rings so thats probably why I am leaking. Expand Yep. Hk7 kit includes the o-rings. I think they are green in color. They are absolutely essential. These are gas-resistant o-rings, you cannot use hardware-store o-rings they will not work. Good luck with it! Link to comment Share on other sites More sharing options...
RiversideMJ Posted July 2, 2024 Author Share Posted July 2, 2024 Reviving this thread to see if anyone else can guide me here. The o-ring kit solved the original leak issue but now it seems the fitting is leaking. So the fitting is no good. I ordered a Dorman Fuel fitting (800-120) and it looks like it would fit the fuel rail but when I got to bottom of truck, there is no connection. The fuel hose is also tearing so I’d like to replace it all. Any tips/suggestions? Don’t feel like taking it to a shop if it’s a simple fix Link to comment Share on other sites More sharing options...
