jamcomanche Posted April 14, 2024 Share Posted April 14, 2024 I originally had a 74 amp CS130 in my 87 2.5 and the bearing went out. Because I have some power fluctuations with lighting and an AMP installed, I decided to upgrate to a 105 amp 8137-3N from WAI Global. After I installed it and started up the engine, the voltage on my dash immediately went into the red at or above 18 volts. After a couple of seconds, it started cutting power repeatedly so I shut it off. I disconnected the output cable from the alternator and the connector and started her again to make sure it wasnt unrelated, and it read around 10-11v on my gauge. I started a return since I assume it's a bad voltage regulator in the alternator if it's pushing out that much voltage, but then I started thinking about what else could possibly be causing it. I ordered a pigtail replacement, which ended up being a 4-wire so I needed to figure out how to wire it up. Then I started looking at wiring threads and the pinout for the 8137-3N. My previous alternator only used the 2 middle terminals on the connector ( L and I/F pins ). When I look at threads about wiring up the CS130 with a 2-pin connection (this one for example), 99% of what I found said it should be using either S+I or S+L pins. Is there any reason I would need to change from the L+I connections to the S+I or S+L connection? Would that possibly cause the high voltage output? Or am I right in thinking it's just a bad regulator in the alt? Any help with this will also help me figure out the right way to wire in the new connector. Thanks! Link to comment Share on other sites More sharing options...
