How to remove door windows
Removing your door window(s) on a comanche or cherokee is fairly easy.
first, remove door panels via 2 screws in the armrest, and 3 screws on the door handle/latch assembly. pull the door panel back, then lift it up, and finaggle with it to get it off the handle assembly.
EDIT: will finish later...
  • 1 month later...
How NOT to remove door Windows:
Pull the panel off
Roll window down
Try to unscrew the torx style zinc plated fastener
Spend twenty minutes trying
Cuss at fastener
Cuss at Torx
Cuss at bean counter that changed the fastener from hex head to torx
Cuss at Engineer who decided this fastener needed 200 pounds of torque
(the backing is basically a nylock nut and washer combined so it slips before it lets go.)
Break window with nearby ball peen hammer (see pic)
Pull whole assembly and try to remove nut from regulator using a vise
Cuss at the parents who spawned the evil genius who designed this clever torture device slash window fastener
Grind fastener completely off and pry off nylock backing while cussing...
Replace with older style fastener from old 1989 regulator.
Thought I'd give you some inspiration.
