Big_Mark Posted February 11, 2023 Share Posted February 11, 2023 Hi gang, I have finally rewired my a/c pump to an in-cab switch so I can repurpose my unused a/c pump for on board air. The next thing I need to do is plumb in a hose from the output port on the a/c pump. which will either be plugged into an auxiliary air tank (under the bed I think) or directly to a hose to fill my tires after wheeling. Unfortunately, I "cleaned up" the stock hose so now I either need to replace it with a "new to me" one (junk yard run) or, better yet have a custom hose/pipe made so I can bolt on regular air hose couplers. Can anyone tell me what hose fitting size and type is used on the circled port below? Thanks! Link to comment Share on other sites More sharing options...
