Ax15 clutch fork orientation?? UPDATE WITH ANSWER FROM ADVANCE ADAPTERS
According to the Advance Adapters tech line, the slots should go towards the driver's side as pictured below. It has been confirmed that people have functioning systems with it reversed, but I prefer to have it the way it is supposed to be. The new system is currently installed and functioning.
I'm installing a new ax-15 and external slave kit from Advance Adapters. Their instructions do not specifically what direction to mount the clutch fork? Just one tiny black and white photo. I found bunch of posts from people trying to figure it out and have found photos mounted both ways. I'm sure it would "work" either way, but I'd like it to be correct and it seems to operate a little differently depending on which side the spring clips are. I did find a diagram on Repair Link  that shows the slots on the driver's side. That's what I'll probably go with if nobody knows. Thanks!
  • Htchevyii changed the title to Ax15 clutch fork orientation?? UPDATE WITH ANSWER FROM ADVANCE ADAPTERS
