cm Posted January 27, 2008 Share Posted January 27, 2008 XJ lifts work for MJ's only as far as FRONT SUSPENTIONS. SO, if you go with the soft ride or super ride RE lift for the XJ. The ADD-A-LEAF that comes with it for the rear, will not give you the correct amount of lift. You'll need to get a MJ ADD-A-LEAF CW ..... wrong .... it may not give 100% of the lift it would on an xj, but you can't say its un level... (this coming from someone whos installed a re 3.5 sf2 kit on an sua mj) Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted January 27, 2008 Share Posted January 27, 2008 XJ lifts work for MJ's only as far as FRONT SUSPENTIONS. SO, if you go with the soft ride or super ride RE lift for the XJ. The ADD-A-LEAF that comes with it for the rear, will not give you the correct amount of lift. You'll need to get a MJ ADD-A-LEAF CW ..... wrong .... it may not give 100% of the lift it would on an xj, but you can't say its un level... (this coming from someone whos installed a re 3.5 sf2 kit on an sua mj) I beg your pardon... XJ leafs do not have the same arch or legnth as a MJ spring. SO, an XJ Add-A-Leaf can NOT possibly offer the same advertised lift for a MJ leaf, period. CW Link to comment Share on other sites More sharing options...
