'88 Drive/Brake/Suspension Parts - GA
howeitsdone
I've got a few parts from the '88 lying around that I'd like to get rid of. Figured I would see if anyone on here needed any of it.
I'll ship anything on your dime through FedEx.
Drag Link Frame Mount - $50
Pitman Arm - $10
Wheel Hub Assys (Work just fine, no squeaks or binding) - $15ea
Control Arms (UCAs have new bushings. One is slightly dented from press) - $35 for all
Brake Dust Shields (Needs a little bending) - $10
Springs (I think they're aftermarket but not sure) - $20
Leaf Spring Helpers (No Hardware) - $25
Dana 35 Backing Plates w/ almost new brakes (L/R) - $45ea
Dana 35 Axle Shaft (RH, has good bearing) - $75
Dana 35 Axle Shaft (LH, needs bearing replaced) - $50
Archived
