Alignment Brainteaser
Sounds to me like either a bent control arm mount or maybe the housing is bent up or down. I would look into a used set of adjustable upper control arms. If you can't dial it in there and your ball joints are good, you've got either a control arm mount issue axle/frame side or the axle housing is bent.
Edit: :or possibly a bent C
