Dickinson County Comanche Posted September 30, 2021 Share Posted September 30, 2021 Hey all. Whenever I shift gear normally now in my Comanche, it makes a very audible clunk/knock. If I baby it, no clunk, no knock, nothing. It also makes this knock if I wind the engine up and accelerate then coast. It is not the u joints of any kind, the front nor rear ones, nor do I believe it is the transmission mount as I just replaced it. I was thinking transfer case chain slap but it doesn’t seem to have a ton of play to suggest it. The input shaft on the transmission did seem to have some play but it was not extreme. transmission and transfer case are from a 1993 Jeep Cherokee. AX-15, NP231. It still retains the original internal clutch setup. Link to comment Share on other sites More sharing options...
Dickinson County Comanche Posted September 30, 2021 Author Share Posted September 30, 2021 The rear axle does not seem to have an extraordinary amount of play either. I never noticed this before I swapped it, not in the Cherokee, nor in the Comanche with the BA10/5. Clutch and flywheel were also torqued to spec and don’t seem to be lose as it sounds just fine when starting and the clutch seems a-ok. Both transfer case and transmission have the proper amount and type of fluid. Link to comment Share on other sites More sharing options...
