sinnaevd Posted October 30, 2007 Posted October 30, 2007 So I have put in an engine out of an 87 YJ into an 86 comanche. There were no differences in wiring, but I am having issues with the vaccuum lines as they are different between the twe system. I have been through my Hanes manual and it hasn't been much help. Now I am using the 87 Intake, so what vaccuum lines can I eliminate and which must I keep? Do I Have to use the canister from the 87 to make it all work properly? The steel tube that connects the intake to the exhaust (bent in an l shape) is also broke. how much trouble is this going to cause?
