fuel pump
You should be running about 31 psi when idling. I've never pushed the pin without a tester on it, but I would assume it would be more. your best bet would be to put a fuel pressure tester on it and see what you're running at.
When my fuel pump died last year it still ran...but was at about 14psi.
