Twisty Posted September 17, 2007 Posted September 17, 2007 Since the MJ is half unibody, half frame...how much does the unibody flex? I might be putting some rather large axles under the MJ, and am curious. I will be plating the frame rails with 3x3 1/4" angle iron...but will that be enough?
87manche Posted September 17, 2007 Posted September 17, 2007 it's way stronger than the XJ. thicker uni frame rails more bonding points for the cab. The rear is a boxed in frame, with some plating it should be plenty stout. It only takes one look at the MJ LCA mount compared to an XJ to know that AMC really beefed up the unibody for pickup truck use. It certainly flexes a lot less than your traditional body on frame pickup truck.
comanchedude Posted September 18, 2007 Posted September 18, 2007 I agree with 87manche its truck tough!
Twisty Posted September 18, 2007 Author Posted September 18, 2007 Good! So with some plating and a few good strong skid plates bolted to the stiffeners...I should be good to go. Maybe a cage to tie everything together at some point. I'm getting a 14 bolt from a guy ~1.5 hours from here for $150, and a pair of D60s from a 1978 F350. I have my eye on 39.5s, and a triangulated 4 link rear. :brows:
