mjtjnj Posted September 11, 2007 Share Posted September 11, 2007 hey for my rebuild, bought an ax-5 out of a 2000 cherokee with low mileage. Boneyard clipped the hydraulic line! All I have is some plastic tubing sticking out of the trans. Does the external slave kit come with everything? Any potential problem in mating this to my clutch cylinder and plumbing on the stock 87??? Thanks! Tom (full of questions) :nuts: Link to comment Share on other sites More sharing options...
87manche Posted September 11, 2007 Share Posted September 11, 2007 external slave kit comes with a new master and slave, permanently tied together and pre bled. You can use a compression fitting to mate your old clutch line to the new one, and there should be a small hole on the slave with an allen head set screw in it, that's the bleeder. Link to comment Share on other sites More sharing options...
