Replacing Distributor
I am pulling the Distributor in order to prime
the oil pump, because the motor has not been
started for a while.
Since it is coming out, I am thinking of replacing the
91 Distributor because I cannot get to the Stator
under the Rotor, without pulling the Distributor.
Is the 94 XJ the same Distributor with the accessible
Stator?
Will this Distributor work with the 91 CPS?
Thanks
youngfred
