LINT838 Posted August 24, 2018 Share Posted August 24, 2018 So, I do not own a Comanche yet, never owned a Jeep in general, but they are sick and I found a 1986 5 spd with like 85000, looks in good condition, new back tires, new brakes and rotors, some aftermarket lights, for only 2500! seems like its too good of a deal, only problem is its 2wd. I guess it used to be 4wd but previous owner changed it for some unknown @#$%ing reason. Current owner says it only needs a transfer case and front drive shaft. Anyone think i should pull the trigger on this ?? I think i should. How hard/expensive is it to to the conversion back to 4wd if it was originally rigged up for it?? Thanks Link to comment Share on other sites More sharing options...
Wounded_Fighter Posted August 24, 2018 Share Posted August 24, 2018 If it needs the transfercase, you might need the rear shaft as well. some of the work is eliminated if it still has the 4wd front axle in it, I think that would be a good 1/4 of the work. Share some pics :) Link to comment Share on other sites More sharing options...
