CB radio question and suggestions
I have a bearcat 880 CB I plan to install just had a couple questions before I get started.
Where did you find the best antenna location? I’m currently thinking I’ll mount it to my toolbox or the the truck bed near the cab. I read an article that suggested placing the antenna on he driver’s side vs in the center. What are your thoughts?
For the cable I think I’ll use RG8x cable. Would you suggest a different cable and why if so?
What is the outside diameter of the standard connector fitting? I’m looking at blue sea systems clam grommet to provide a waterproof seal for the cable to pass into the cab.
As for the antenna I’m looking at the firestik 5’. They seem to have a good range and are very durable. Would a antenna Spring be suggested?
Thanks for you input and suggestions!
