SoloCamo Posted September 27, 2007 Posted September 27, 2007 I did notice a difference on low end, but I haven't swapped out the restrictive muffler yet. I suspect that will help a bunch. I didn't install the intake for performance(but I'll take it). I just wanted to eliminate the bulky stock airbox. Was it a good improvement on the low end, or are you saying it took away some power from the lowend and moved it higher up top?
