Joseph Edelmann Posted March 14, 2018 Share Posted March 14, 2018 As several have noted, the fuse panels get melted by clutch and or brake fluid. i need a replacement fuse panel. I have two part #'s: 81 J 082 2000 0r J4179458 Photos of the existing one are attached. Any and all replies are welcome Thank You Joe Edelmann Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted March 14, 2018 Share Posted March 14, 2018 Went through the same thing on a 85 XJ. Only once in three years did NOS fuse box come up on eBay, all it is is the the plastic assembly no wires.Best solution is junkyard dash wiring harness, possibly from an automatic is possible.The tricky part is there are not going to be a lot of 86 XJ or mj in the junk yards any more. Car-part . Com and hollander parts to sea has used inventories on line.But I think all the Renix era dash harness may work. I put a 88 dash harness in along with a 86 2.8 engine harness. It bolted up and works. But I don’t know if it’s true for all Renix era XJ/MJ or if I got lucky and it worked with the 2.8 harness. In the electric trouble storing guides the bulk head connectors look the same but there is no interchange I know of, best way is to match year and options.Another possibility is trying to take it apart and clean it.Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 15, 2018 Share Posted March 15, 2018 The 84-93 XJ / MJ fuse panels themselves are identical, p/n J4179458. The only differences were how the terminals are populated. These can be found in several places, like: https://www.waytekwire.com/item/32030/PACKARD-56-SERIES-MALE-12-GA/ and http://www.repairconnector.com/products/Brass-ATO-Fuse-Block-Terminals-10-Pack.html Link to comment Share on other sites More sharing options...
