Ghost Posted February 19, 2018 Share Posted February 19, 2018 Looking for some MJ specific help here. I have an 88 that the column was sloppy on. Well I tore it down and tightened the annoying bolts in it. When I put it back together shortly after the ignition quit moving freely. So I tore back into it and found the rod bent. I pulled a column out of a parts xj and the rod is completely different. Is it possible I basically bent the rod straight? Anyone have a column out that can post pictures of how the rod goes in the switch and how the switch mounts on the column? Link to comment Share on other sites More sharing options...
