Hiroler Posted May 11, 2017 Share Posted May 11, 2017 Hi guys I settle on a townhouse in Somerset NJ on May 19 and need a car for my 160 mile commute to Baltimore. I'm currently commuting 60 miles a day in the Comanche on I-95 between 20904 & 21226. I've put 1500 miles on it in the last 2 months since turning in my leased car. I bought the truck on eBay March 2013 and have done a considerable amount of work to it since then. The motor recently developed a slight misfire which is most noticeable at highway speeds. It began when a hose fell off the fuel pump. I've replaced injectors, plugs, wires, fuel pump fuel filter, etc and it runs great aside from the misfire. I have a new O2 sensor but haven't installed it yet. I suspect this is an issue because my fuel mileage isn't great. Basically everything works except for the A/C which is unplugged. The oil pressure gauge didn't work for 3 years and suddenly started reading 60psi at startup and 20psi on the highway... then went back to sleep. The 4x4 works great. The driver's side floor pan was rotted out so I covered it with sheet metal when I replaced the ebrake cable. I had the transmission out last year to replace the flex plate. I accidentally cut the CPS wires so I replaced that. I replaced the transmission lines and brake lines. It doesn't leak or use any fluids Aside from a drop or two of oil from the valve cover. The wheels are from an '01 Cherokee classic with new BFG tires. The aluminum cap covers a solid bed that is carpeted for my dog. There's a tonneu cover as well. The left side of the bed was rubbed against by a fire truck and the right side sustained a little damage when my wheel bearing failed (new wheel bearings!!). No real rust underneath, just cosmetic on rockers and rear wheel well. I'd like to sell to a hobbiest willing to continue maintaining the truck. I'm only asking for $2500 obo Link to comment Share on other sites More sharing options...
Hiroler Posted May 11, 2017 Author Share Posted May 11, 2017 It's automatic. I'm trying to figure out how to post pictures. Link to comment Share on other sites More sharing options...
Hiroler Posted May 11, 2017 Author Share Posted May 11, 2017 Link to comment Share on other sites More sharing options...
Hiroler Posted May 11, 2017 Author Share Posted May 11, 2017 PA title and inspected through Nov 17. Inspection is not an issue with this truck. You can drive it 1000 miles home if you want to. I drive it 80 miles to PA regularly. Link to comment Share on other sites More sharing options...
Hiroler Posted May 21, 2017 Author Share Posted May 21, 2017 Sold to a great enthusiast. He wasn't able to sign up for these forums but he found it on Craigslist. Thanks Link to comment Share on other sites More sharing options...
Archived
