Monroe Comanche Rear Shock Application Sheet
For anyone interested, here is a application sheet for Monroe shocks for the rear of the MJ's.
http://www.greatlakesxj.com/tech/MJRearShock.htm
Disclaimer: I have not confirmed every shock on here will work. This information is based on the mounting and length chart that Monroe puts out. I have included what the stock one's are as well as extended for lifted and shortened for lowered vehicals as well. This is intended to simply be used as reference, make sure you do your own research as well prior to your purchase.
